Meraki MX Licenses--Confusion
Mohammad
Hi Champs,
I am planning to Buy two MX and planning to implement in Active and Standby, but confuse with Licensing part, should i go with 2 licenses for separate box are should i go with 1 licenses for active and no license on standby?
Please help!
Regards
4 REPLIES 4
DensyoV
You should only need one MX license if you are just going to configure it in a warm spare or Active and Standby.
hope this helps.
Please hit kudos if you found this post helpful and/or click "accept as solution" if this solved your problem.
Thanks Den for your prompt response!
can i configure in Active /Active also with One license or required 2 separate licenses?
Meraki only support warm spare set-up so Active/Active is not supported at the moment. Once you remove the spare MX and place it into a different network, it will require a license.
Thanks Mate for simple clarifications!
Any specific reason not supporting Active/Active Scenario in MX, due to  ASIC or hardware limitations for any other things?
