Meraki Local Auth - Failed due to RADIUS timeout (127.0.0.1)
_Pietro
Testing two possible configurations and wondering if anyone is actually using Meraki Local Auth successfully.
Configuration 1:
LDAP server specified is Azure AD DS private IP. APs have connectivity over site to site VPN.
Configuration 2:
LDAP server specified is DUO Auth proxy which then redirects to Azure AD DS.
Both configurations pass on the dashboard when testing against the specified LDAP server. I am able to connect and bind from the APs subnet to both scenarios. There is only 1 active AP to keep things simple.
Both configurations fail when attempting to connect to the SSID by an actual client, for the same reason:
Client xxxxx had a failed connection to SSID xxxx on AP xxxxx during authentication because the auth server did not respond.
RADIUS SERVER
127.0.0.1
MERAKI REASON (CODE 100)
RADIUS timeout
Tested with a MR33 and a CW9162I
Edit:
Password authentication is used.
2 REPLIES 2
_Pietro
Just wondering if anyone is actually using Meraki Local Auth successfully? My support case has been open over a month and feedback has been pretty vague.
Claudiosm
I'm attempting to use this feature without On Prem to validate Local Auth with Okta acting as LDAP. No support has been able to help, and the documentation is not very specific. I can communicate with Okta ldap over port 389 but when i attempt to connect a client on site i get a similar issue, AP just timeout.
