MTBF for MR46, MR56 and MR86
Jbarb
Where can I find the MTBF for MR46, MR56 and MR86? This information is not on the datasheet.
Thanks in advance
6 REPLIES 6
MerakiDave
Re: MTBF for MR46, MR56 and MR86
Hi @Jbarb the MTBF should be 450,000 hours across all 3 of those models, will confirm and let you know.
jdsilva
While @MerakiDave is most likely correct (he's great with getting us answers here on the community!) the "official" way to get these numbers is to simply call support and ask. They'll happily provide you with MTBF numbers for any Meraki device.
Jbarb
Thank you very much for your help.
Best regards
Jbarb
Hi jdsilva,
My first approach was to open a case on Cisco Meraki Support. But the reply was "Unfortunately, this is not something that support can provide. You should be able to get this information from your account manager (help -> Get help)".
Since it was urgent (just needed that to close the answer to an RFP) I have used the MTBF indicated by MerakiDave.
Best regards
jdsilva
It seems either something changed or you got a support person that didn't know they could provide them. I have for sure in the past got these numbers from support.
https://community.meraki.com/t5/Wireless-LAN/MTBF-MR74-and-MR53/m-p/50833#M7771
MerakiDave
@Jbarb just closing the loop on this, I circled back with the MR team and the MTBF values have been added into the data sheets maybe a week or two ago.
MR36: Mean Time Between Failure (MTBF): 174,300 hrs at +25°C operating temperature
MR46: Mean Time Between Failure (MTBF): 1,406,652 hrs at +25°C operating temperature
MR46E: Mean Time Between Failure (MTBF): 1,328,360 hrs at +25°C operating temperature
MR56: Mean Time Between Failure (MTBF): 1,315,498 hrs at +25°C operating temperature
