MR74 & Ant27
frenz
MR74 & Ant27
Hi!
On wich Ports (2,4 GHz or 5 GHz) can i connect the ANt27?
thx
Richard
Wireless, what else?
MerakiDave
You can connect the ANT-27 for either frequency, ANT-27 is a dual band sector.  On the MR74, 2 ports are for the 2x2:2 2.4GHz radio and the other 2 ports are for the 5GHz 2x2:2 radio.  So just make sure you're plugging the ANT-27 into the 2 ports on the SAME side of the AP.  Even though the ANT-27 is dual-band, you'll basically be using it as a band-specific sector antenna, because on the MR74, the antenna ports are single band, two for 2.4 GHz and two for 5 GHz.  So you would use 2 ANT-27 antennas per MR74 AP to provide the dual-band coverage.
2 Replies 2
MerakiDave
If I only want to have 5 GHz coverage, is it allowed to use the MR74 with a single ANT-27?
