Are the MR45 mounting brackets the same as the MR33?
Are all MR APs supplied with the same type of mounting bracket?
Solved! Go to Solution.
Probably not. They have always been different so far:
https://meraki.cisco.com/products/wireless/mount-kits
They're always included though.
MR45 uses MA-MNT-MR-14 so it's different.
Thanks for the swift response, that's the info I was looking for!
Glad I could help.
