MR42 Meraki - iMac - disassociation - client not authenticated every 1 minute or so
RanVijay
Hi Team,
Need help in determining the possible root cause for this issue, I've been observing the iMac in the room always disassociating with the AP.
Sometimes the user reports that he gets a reconnecting warning during on-call using MS Teams.
  • Could this be a possible cause for the user to get dropped in calls?
  • What can we look into and possibly how to fix this?
Thank you!
3 REPLIES 3
AnythingHosted
Which firmware are you running?
I have found this problem and it has been added to the list of known issues (although Meraki claim the client doesn't disconnect). I, however, have experienced the client disconnecting.
I've moved to WPA2 and WPA3 transition and that seems to have solved the problem for me.
Thank you for your response
AP Version is: 26.6.1
I'll look into this.
I've also opened a case with Meraki hopefully they can get to see the root cause...
With a 42 you can go to 27.3, it is much better than prior 27.x releases and (for us) all 26.x releases
