Search instead for
MR33 DNS error
MR33 DNS error
I'm having an issued,  on my MR33 I can get v4 IP from DHCP on vlan1 (Native) and dashboard say DHCP error on vlan1 and my cell phone say could not get IP and then no connection i have 98% Free address and I reboot more then one time too. Firmware 25.9.
Any solution?
StarFX
9 REPLIES 9
Re: MR33 DNS error
If you unplug the access point and plug your notebook into the same cable does your machine get an IP address and can it access the Internet?
Re: MR33 DNS error
A screenshot of that AP with the error in dashboard may also help us give you some advice.  But @PhilipDAth suggestion is a good place to start.
Re: MR33 DNS error
Hi thanks for the quick response,
I made a mistake it not a DNS error it a DHCP error sorry for the confusing. See picture
StarFX
Re: MR33 DNS error
@lavoiea01 wrote:
If you click on the values in the Failures columns, you can see which devices caused the problem.
Some phones don't handle the splash screen properly so guests may fail to click through (which causes an apparent failure). Other failures can occur when a device is in a marginal location. I found it happened when testing and if the mobile device did not keep up with the AP.
Hopefully, as this feature becomes mainstream, it will filter out the false positives.
Re: MR33 DNS error
When i click the error it say's ''vlan1, DNS Error'', and i do not see the error
StarFX
Re: MR33 DNS error
@lavoiea01
If you click on the value showing under DHCP failures (5/5), the panel showing the details of the failures will drop down.
In the above case, all the DHCP failures are caused by devices attempting to access the Guest network who do not click the splash through (just legal disclaimer). Depending on the device they are treated as either an untagged DHCP failure or a guest VLAN  DHCP failure. They are not actual failures.
Re: MR33 DNS error
I am facing  an issue of DNS configured mismatch in MR33 AP's...please help on it..what could be the issue..
Spoiler
Re: MR33 DNS error
Can you show us your LAN settings on the AP?
Re: MR33 DNS error
Hi @Prafull_Koli
The error you get at the top left refers to a problem with the DNS configured on the MR33, so it's related to its LAN configuration.
The DNS failure you have highlighted refers instead to the clients.
As you are experiencing problems on both, I would consider investigating the DNS first, make sure it's reachable and the DNS service is running.
Giacomo
Please keep in mind that what I post here is my personal knowledge and opinion. Don't take anything I say for the Holy Grail, but try and see!
Appreciate who helps and be respectful of every opinion and every solution offered.
Share the love, especially the Meraki one!
