Search instead for
MR Firmware 26.2 Available
New
  • Initial stable firmware for MR45/MR55
  • Improved efficiency & reliability of Auto Channel CSA process
  • RADIUS Proxy support for client 802.1x authentication on MR LAN ports (MR30H/MR52/MR53/MR84)
Bug fixes
  • Additional clients unable to associate to APs with 40+ active clients (MR26/MR32/MR34MR72)
  • Clients unable to EAP reauthenticate after EAP session timeout (MR26/MR32/MR34/MR72)
  • RADIUS authentication would not failover to secondary RADIUS server when used in conjunction with VPN Teleworker or Layer 3 Roaming with Concentrator (All MRs)
  • AP not failing over to secondary RADIUS server quickly enough to prevent some clients from disassociating and restarting failover timer (All MRs)
  • Corner case where AP would not properly load radios upon boot (MR26/MR32/MR34/MR72)
  • Prevent BPDU frames from being sent over VPN tunnels in Teleworker VPN configurations (All MRs)
  • Comma delimiter in RADIUS accounting fields caused unexpected behavior with Windows Network Policy Servers; replaced with forward slash (All MRs)
  • Local Status Page showing incorrect values for client max bitrate (All MRs)
  • Corner case where beacon interval may become misconfigured for 200ms instead of 100ms (MR42/MR42E/MR52/MR53/MR53E/MR84)
  • Corner case causing APs to reboot (MR42/MR42E/MR52/MR53/MR53E/MR84)
  • Client isolation used in conjunction with upstream HSRP configuration resulted in client being unable to ARP for their default gateway (All MRs)
Known issues
  • Issue under investigation where DHCP intermittently fails for bridge mode SSIDs (MR32)
  • Mesh instability (MR18, MR20, MR33, MR34, MR42, MR52, MR53, MR53E, MR70, MR74, MR84)
  • Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID’s (All MR’s)
Other
  • New Features
  • Bug Fixes
  • Known Issues
Nolan Herring | nolanwifi.com
TwitterLinkedIn
7 REPLIES 7
Re: MR Firmware 26.2 Available
New APs coming! Anyone seen details on them yet?
You'll probably enjoy April the 29th.
Aha I see. Pinned in the calendar!
Got a partner update in this week for EMEA. Good stuff.
Will be neat to see how things perform on this version of code.
TwitterLinkedIn
I guess the news is out then Smiley Tongue. I thought it was supposed to be a secret until April 29th...
Points Contest
Join us for a month-long contest with heaps of swag to win!
Learn More ›
