Is the MR57 also an MT14?
From the Cisco 9136 spec sheet:
Environmental sensors
These built-in sensors measure air quality (Total Volatile Organic Compounds [TVOC]), temperature, and humidity, and help ensure a safe working environment, avoiding the need to install an overlay of difficult-to-manage independent sensors.
Perhaps the MR57 will also have this enabled?
4 REPLIES 4
MerryAki
That’s a good question, at least this stats should then appear within the MT section of a Meraki dashboard. (I doubt that it will need an MT and ENT lic)
Thrilled to see it in action soon.
I would not count on it. Only the housing is the same. Mr57 is different hardware
Ryan_Miles
redsector
would be a really good thing!
