Is possible to create Administrator role for WIFI Guest network splash page only
ProtoMatt
Hi, we manage a full Meraki deployment for our customer. Their Marketing team has requested the ability to modify the content of the splashpage for the Guest WIFI only (no other WIFI networks). Is it possible to create such an admin role that has no other R/W privileges to wider devices or policies on said network?
To clarify, they are only using spashpage on the Guest wifi, there is no other splashpages setup for Private Corporate wifi networks.
many thanks, Matt
You might be able to do something with Boundless Digital, as they support fine-grained access control.
https://www.boundlessdigital.com/
You could get them to deploy an external splash page, on their own server.  Here is an example written in PHP.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Configuring_a_Custom-...
Otherwise, no.
You could also use a third-party provider, like Splash Access.  Splash Access is super popular.
https://www.splashaccess.com/
The marketing team will particularly like Splash Access, as it has a million controls designed purely for marketing departments.
I think you should look at Splash Access first as the extra marketing functionality will make it a slam dunk solution.
