I ha
Mohit_Dhanjal
I ha
I have assigned static IP to MR-46, now it is showing SSID names as hidden-network, it is not connected in dashboard as of now.
Why it is showing hidden-network.
Regards
Mohit Dhanjal
9 Replies 9
It's a Meraki setup SSID. Just put the AP on the dashboard and It will disappear.
okay, as of now i have connected my AP's to POE switch and getting raindow LED continuosly.
What is the meaning of the same.
Regards
Mohit Dhanjal
Does your AP have an internet connection?
https://meraki.cisco.com/blog/2014/02/the-light-fantastic/
@Mohit_Dhanjalyou can find all the information in the Meraki documentation.
Not connected through internet. But getting Rainbow light continuosly.
Regards
Mohit Dhanjal
Without an Internet connection, It will not work.
OrangeAP is booting
Blinking BlueAP is upgrading firmware
GreenAP in Gateway mode with no clients associated
BlueAP in Gateway mode with clients associated
Blinking OrangeAP can’t find an uplink
Mohit_Dhanjal
Mohit_Dhanjal
what is the IP address for Dashboard.meraki.com
Are you serious?
If you want to allow Meraki IP range, go to Marki Firewall info on the Meraki dashboard.
