How to block Windows Update
Prashan
Hi Team,
How can we block windows update from Meraki ? I'm using M42 access point. I want to block Windows update
7 REPLIES 7
AjitKumar
Hi @Prashan
I understand L7 Firewall rules should help you to achieve this.
On the dashboard go the following option and Deny the Category.
Wireless > Firewall & traffic shaping > Select the desired "SSID" > Block applications and content categories - Layer 7 firewall rules > Software and anti-virus updates
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Thank you @AjitKumar
So is it included in Software updates, i thought OS updates not included in software updates?
Do you have any idea What software updates included in Software updates category ?
AjitKumar
Hi @Prashan
I am not aware of any document or information except the following content, stating the "List of Software's" included in this Category.
"The Cisco Meraki cloud-based application signature database is constantly updated to identify new and changing applications, without requiring the administrator to download and install software updates. The Cisco Meraki cloud-based architecture continually learns based on activity from Cisco Meraki's thousands of customers and millions of users, increasing the accuracy and precision of application fingerprints."
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Can we restrict Apples Updates and Android updates
AjitKumar
Hi @Prashan
Is the L7 Rule not working?
If not you may block the host name. Check the following url for iOS.
https://documentation.meraki.com/zGeneral_Administration/Other_Topics/Blocking_or_rate_limiting_iOS_...
For Android I believe above will be challenge as they have various sources. I believe Cisco Meraki EMM may help you on this provided you "OWN" the devices.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
app store is cannot access, but playstore is can access at the moment
