Exporting login attempt details
AdBurl
Hello all
After receiving an email from Meraki about unauthorised logins we are looking into how we can export our login attempt logs to a syslogger or similar.  Has anyone done this previously or know if it is possible? We can't see an option to export the logs in this way.
5 REPLIES 5
AdBurl
sorry, to clarify this is administrators logging into the dashboard not user connections to wireless network
AxL1971
I did look at this, can not see any API calls to get this info and the syslog settings are from the devices and not from the portal
The only other possible way is to use the Webhooks, this would need an on premise server to process any inbound API call
I don't know the answer.
Going sideways - perhaps you could use SAML authentication to the dashboard instead, and query the SAML provider.
https://documentation.meraki.com/General_Administration/Managing_Dashboard_Access/Configuring_SAML_S...
Thanks for the reply, SAML is something we'll have a look into
There is no API for this, just to Get organization login security.
https://developer.cisco.com/meraki/api-latest/#!get-organization-login-security
