Anyone aware of a way to have an SSID broadcast 2.4Ghz only? I require this for my RF guns.
Solved! Go to Solution.
@pablo wrote:Anyone aware of a way to have an SSID broadcast 2.4Ghz only? I require this for my RF guns.
Couple of ways you can do this:
I'd recommend the first since it is the cleanest.
According to this site you can:
https://cantechit.com/2015/08/21/meraki-can-do-only-2-4ghz-on-wireless/
I have not done this myself so cannot vouch for the accuracy of the info provided.
What about on the MX appliance ?
You cannot disable this completely on an MX, unfortunately. We seem to have found a workaround, though:
Minimize the power of the 2.4 GHz band to make it virtually invisible by setting it to 1 dbm.
Of course, don't do this if you have any devices that cannot use 5 GHz, because those devices will no longer be able to connect.
