Customise Wi-Fi Guest Landing Page
DPJW
Is it possible to customise the Guest landing page on Meraki Dashboard?
For eg. remove Cisco logo, replace with company logo? Change the landing page background to other picture?
AxL1971
You can, we have done this to customise the page to include company logo etc
You can edit the html file
What we did was create a copy of an existing theme and edit this copied theme.
If you click the pencil icon of the copied theme, you can select the relevant html file and edit it.
Option to replace the logo on the Splash Screen page.
Brash
You can perform some customisations under wireless -> splash page but it's somewhat limited.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Splash_Page#Customizi...
For more customization options, you can redirect to your own server and build a splash page, or use an integration such as Splash access.
AxL1971
DPJW
Ok thanks @AxL1971 . Although is limited to that specific customisation, but it should be sufficed alter their default captive page
