Custom Splash Page with SMS authentication
MichelRueger
Hi All,
Does anybody already did a Custom Splash Page with end up in a SMS Authentication on Twillion?
I habe a customer witch wants to ask for Name Mobile Number and E-mail and save this information in a Database, and then give the Mobile number over to Twillion. I Know how to make the Custom Splash Page and write the infos into a Database but i didn't find any information how to give back the Mobile Number to the Meraki Dashboard?
IS there somebody already did something like this?
Thanks for Any Help
Michel Rueger
3 REPLIES 3
Re: Custom Splash Page with SMS authentication
I'm pretty sure Splash Access can do this (including sending the TXT message).
https://www.splashaccess.com/
DCooper
Meraki Alumni (Retired)
@MichelRueger Your not handing anything back to the Dashboard when your performing EXCAP except for either a url grant with splash page design or access-accept with sign-on design. See the document below then we can further discuss on here how to get it to work. Would you be using username+password+SMS(RFC6238)?
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_captive_portal.pdf
DCooper
To clarify. Currently You cannot send any phone information back to the dashboard using EXCAP. If you wanted that information in Dashboard you would have to use our custom splash page with integration into Twilio. This is hosted on the AP but served from the cloud.
https://documentation.meraki.com/MR/Splash_Page/Splash_Page_Overview
