Client is disassociation - unknown reason
Hello!
I faced with problem when users connecting to WIFI (Open SSID with Radius server authentication). User's devices is connected well, but when its go to power save mode (lock screen on IOS or Android), AP disconnects device.
802.11 disassociation
unknown reason
Devices in lock mode are connecting to 3G/4G. But when i unlock devices it connects to WiFi again.
How it can be changed that WiFi will be connected permanent?
All mobile devices face this problem
AP MR18
Current version: MR 25.13
8 REPLIES 8
Re: Client is disassociation - unknown reason
Hi Sawka,
it´s the normal behaviour of mobile phones to save battery. It is also often discussed on several apple forums.
You could try to plug the mobile in and see if it stays connected.
Hi Nydo89,
I connect to other AP (no-Meraki) my mobile phone and when i've locked it, WiFi is available on phone (disconnection isn't).
I think mobile devices send information to AP that device go to power save mode and AP (controller) interprets it and disconnects device (if this configure in AP/Controller).
I want to change it for Meraki AP
It could have to do with it being an open network, I would recommend starting with WPA2, since that is one of the most common. You might try setting up an test SSID and making some changes there.
Thjere are no options to control power negiation on the Meraki side.  Perhaps there are some power save properties on the phone you can adjust.
we have to use open ssid with auth on radius - it's standard
no, all testing phone have same setting, they work well in other WLANs. It's issue Meraki devices
Hello everyone, I am having exactly the same problem, the computers disconnect from the network, simply for nothing ... totally random, probe with WAP2, with Open SSID, with all cases the same thing happens to me.
Jun 30 15:31:20MDLZ_MOD13_AP05MDLZ_Depoandroid-6b85ec9b8c76ac70Disociación de 802.11unknown reason
Jun 30 15:26:03MDLZ_MOD13_AP03MDLZ_Depoandroid-6b85ec9b8c76ac70Disociación de 802.11unknown reason
Jun 30 15:25:48MDLZ_MOD14_AP06MDLZ_Depoandroid-6b85ec9b8c76ac70Disociación de 802.11unknown reason
Jun 30 15:25:20MDLZ_MOD14_AP05MDLZ_Depoandroid-6b85ec9b8c76ac70Disociación de 802.11unknown reason
Jun 30 15:25:19MDLZ_MOD14_AP03MDLZ_Depoandroid-6b85ec9b8c76ac70Disociación de 802.11unknown reason
Jun 30 15:25:16MDLZ_MOD14_AP04MDLZ_Depoandroid-6b85ec9b8c76ac70Disociación de 802.11unknown reason
I am also having the same issue on WPA PSK and on 802.1x radius SSIDs.  I am on MR 26.8.1 firmware
