Client connecting on 2.4GHz but SSID is set for 5GHz only?
IanTerry
MR55 with 2x SSIDs, one of which is configured to be 5GHz only - the other SSID is 2.4/5GHz with band steering.
Noticed that my laptop is connected to the 5Ghz only SSID but is identifying its connected with 2.4Ghz ! Only when I change the adapter setting to be 5GHz only and not "Auto" does it then correctly display the 5GHz details.
If an SSID is 5GHz only, why does a laptop successfully connect at 2.4GHz ? Is this related to RF Profiles whereby an AP, by default, provides both 2.4 & 5GHz??
Thoughts welcome, because its not making much sense.
regards, Ian
6 Replies 6
Where did you configure  this. At access control?
Because the rf profile needs to be set correctly first. (per ssid)
IanTerry
Yes set under the Access Control for the SSID
The RF Profile is default for indoor (Basic Indoor Profile).
Therefore are you saying that I need and RF Profile for each SSID and then apply to Wireless Access point?
No.
You can go to the rf profile. And set it to "per ssid". Only then it will start using the access control page band settings
IanTerry
OK - the default profile looks to be fine as it is for now - will try as you suggest.
IanTerry
Great - seems to be functioning as expected now.
Thank you very much for your time and consideration
My guess - client Wifi driver bug.  I would update the WiFi driver on the machine before doing anything else.
