Cisco ISE hotspot integration with Meraki AP
AhmedGadi
Hi All,
          We are in process of integration of Meraki access points with Cisco ISE 2.4 and utiliza hotspot feature of ISE for our guest open SSID configured on Meraki AP.
I have found few documents from Cisco as well as Meraki, but could not accomplish my task.
Look forward to seea positive response from experts.
3 REPLIES 3
BrechtSchamp
redsector
We have got ISE for our wireless.
This is the SSID for Active-Directory Users, the ISE decides if the device has an certificate or not.
If certificate is ok: user has internal access
if no certificate: the user gets an Internet access only f.e. for his mobile devices, cell phones, iPads and so on.
It´s a two factor check: Active-Directory account + certificate on the device. And a easy to use with only one SSID for the employees. Guests have an own SSID.
Meraki SSID config:
You need to set up the rules on the ISE correctly.
And this is important:
You need to put in every Accesspoint with it´s IP-Address as allowed network address:
Cmiller
Thanks for this info, Might be a project in the near future for me
