Apple Macbook Air Dropping WiFi connection while Airplay
This is the error that I see from client
Unexpectedly disassociated, but the client had a successful connection to SSID BJPWLAN for 2 minutes on AP G214. CHANNEL 48 BAND 5 GHz SNR 61 dB TIME TO CONNECT 1550 ms 802.11 REASON (CODE 34) Missing Acknowledgements
Thanks for the reply finally figured it out with the help of Tech support. It looks like the Client Balancing feature was moving the clients to another AP while they were air playing. Turned it off and it solved the issue
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
