Alphanumeric Sender ID using Twilio account API
M2Film
Hey all.
I setup a Twilio account to send SMS authentication using the splash pages. This is all working very well.
However, I can't seem to configure Twilio / Meraki to use an Alphanumeric Sender ID - this is part of the Twilio API.
Anyone tested this?
4 REPLIES 4
BrechtSchamp
Re: Alphanumeric Sender ID using Twilio account API
You'll have to configure it in Twilio. It's a general setting for all SMS's sent by your account. It's not supported on the free trial though.
More info here:
https://support.twilio.com/hc/en-us/articles/223181348-Getting-Started-with-Alphanumeric-Sender-ID-f...
nehasinghjk
Alphanumeric Sender ID allows you to set your company name or brand as the Sender ID when sending one-way Text SMS messages to supported countries. Alphanumeric Sender IDs may be up to 11 characters. Accepted characters include both upper- and lower-case ASCII letters, the digits 0 through 9, and space: A-Z, a-z, 0-9.
Source By SMSala
Eskil
I've tried this, but there is no way I can get Meraki to either choose the messaging service with the alphanummeric sender or specify the "from" field.
Can you explain how you configured this?
SMSSQUAD
if you need branded sms then you should do business with sms squad it is easy way to build your business.
