Adding AP from Inventory to Network doesn't work
softcake
i temporarily removed an Accesspoint from my Network. Now i want to join back again, but it doesn't work.
If I go in Dashboard to my Network -> Wireless -> Access Point and click on "Add AP's" I choose the AP from the Inventory (checkbox) an click on "Add Devices"
After that I get a red bar in the dashboard, without an error message... and no access point was added to the network.
Any Ideas?
Thanks for your help
3 REPLIES 3
RobHuijser
Can you also try to go the inventory, select the mentioned AP's and then add these AP's to the selected network.
same behavior. The AP doesn't added to the selected network
Sounds like a bug. I'd contact the helpdesk.
