AP mr33 internet speed
Hi Everyone,
Could you please help me to resolved issue.
We have ISP 946 Mbps download and upload, and our office is about 20x10 m where installed 5 APs mr33 configured Dual band operation with Band Steering from 11 to Higher Density.
when user connected to WiFi he can get speed only 300 downloads and upload Mbps, see properties client workstation
SSID:      *-WIFI
Protocol:             Wi-Fi 5 (802.11ac)
Security type:    WPA2-Personal
Network band:  5 GHz
Network channel:            36
Link speed (Receive/Transmit):  780/780 (Mbps)
Manufacturer:   Intel Corporation
Description:       Intel(R) Dual Band Wireless-AC 7265 #2
Driver version:  19.51.27.1
Physical address (MAC): 10-F0-05-E9-BA-3D
and also another workstation when connect to the same WiFi only channel different and he get next internet speed   46 Download and 68 Upload Mbps
SSID:      *-WIFI
Network band:  5 GHz
Network channel:            136
Link speed (Receive/Transmit):  173/86 (Mbps)
Manufacturer:  Qualcomm
Description:       Qualcomm
How I can resolved this issue ?
thank you very much ,
6 REPLIES 6
Re: AP mr33 internet speed
You 5g channel is on 40MHz or 80?
At 40 you can get max 400Mbit
At 80 Max 866Mbit.
Aggregate data rate of up to 1.3 Gbps*
A 5 GHz 2x2:2 radio supporting 80 MHz channel widths and a
2.4 GHz 2x2:2 radio supporting 40 MHz channel widths offer a
combined dual-radio aggregate frame rate of 1.3 Gbps*, with up to
866 Mbps in the 5 GHz band
Is the 5GHz running at 80 Mhz on the AP?
thank you for your help see below configuration
could you tell me please why one workstation can get 300 Mbps speed but another one which one different only channel get 45 Mbps
Because  that client was on the 20mhz ap
I got it, but I should configure not auto just add 80 mhz and for 2.4 should change to 40 mhz ?
And also one user get 80mhz but the speed is max 320 Mbps do you know where I should have a look configuration to increase speed ?
thank you very much,
could you tell me please if we have not big office 20x10 with glass walls and we have 5 APs mr33, we have next configuration see below is it correct ? also our APs support legacy 802.11b data rates, is it good practice if  to disable for increased network performance
Also we configured Transit power 6-10 dBm
thank you very much
