AP has too many associations
GoMurica
Can anyone tell me what the log message "AP has too many associations" means?
8 Replies 8
american_nisei
Yes, I get those too as well.   What's weird is this happens a lot when there are only 7 or 8 actual connections.
Are they MR33's?  We had this issue when we added some MR33's, you have to use the latest beta to resolve it.  Certainly, at the time (a few weeks ago) the current stable didn't actually support an MR33.
GoMurica
They are indeed MR33s. So all I need to do is update the firmware?
Yes, to the beta firmware. Just be aware to read the release notes in case the beta introduces other problems.
We are running the beta, but have an open Meraki ticket as there is a bug with radius accounting messages but it’s better than not having clients connect to the APs.
Donnie
geez ... what a nightmare. The latest and greatest firmware (24.12) has not solved my problem. I have 4 MR33's and all day long I get users bumped off the network with "AP has too many associations".  The particular AP below has a max of 7 clients throughout the day. I'm rebooting the AP constantly in an effort to keep these people working (sales environment). I'm very unpopular this week. I'll keep looking for a solution but was hoping Cisco would come out with something soon ... it used to work beautifully.
pjc
Epic fail with having different model AP's in the same network, but some models need to run on Beta and others on production, but when you upgrade firmware, you have to apply it to every AP in the network
So the only answer is to create another network, replicate all of the settings, client whitelists, etc, put the (MR33) AP's in that new network and apply a later firmware version to it...what a faff, c'mon Meraki sort it out
JRH
Meraki support can pin firmware versions to specific APs so you can run different firmware on APs in the same network.
Pedro
@Donnie
I also use the MR33. And I have the same problems.
There is no solution or they simply take over the problem or change the solution.
See this post is just that.
https://community.meraki.com/t5/Wireless-LAN/Constant-association-disassociation/td-p/2772
Good luck.
Pedro
Pedro Constantino
