Hi AlbertoAlfaro,
Welcome to Meraki Community.
In addition to alemabrahao comment, Advanced Malware Protection (AMP) is an industry-leading anti-malware technology, integrated into MX Security Appliances.
Check this article here - "Cisco Talos discovered a malicious campaign using Cisco Secure product telemetry on Oct. 12, 2021 targeting vulnerable Microsoft Exchange servers and attempting to exploit the ProxyShell vulnerability to deploy the Babuk ransomware in the victim's environment"
Do you see the Security Event for "Babuk ransomware" under Organization > Security Center?
If yes, what's the result under "Action" column - block / allow?
(1) - AMP is available only with Advanced Security Edition licensing and SD-WAN Licensing
(2) -
Traffic Analysis must be enabled under Network-wide > Configure > General > Traffic analysis for AMP to function.(3) -
The MX Security Appliance will block HTTP-based file downloads based on the disposition received from the AMP cloud. If the MX receives a disposition of malicious for the file download, it will be blocked. If the MX receives a disposition of clean or unknown, the file download will be allowed to complete.
The supported file types for inspection are:
- MS OLE2 (.doc, .xls, .ppt)
- MS Cabinet (Microsoft compression type)
- MS EXE (Microsoft executable)
- ELF (Linux executable)
- Mach-O/Unibin (OSX executable)
- DMG (Apple Disk Image)
- Java (class/bytecode, jar, serialization)
- PDF
- ZIP (regular and spanned)*
- EICAR (standardized test file)
- SWF (shockwave flash 6, 13, and uncompressed)
* This includes the inspection of XML-based Microsoft Office file types (.docx, .xlsx, etc.).
(4) Additional option for integration - Cisco Threat Grid is a unified threat intelligence and malware analysis platform, which is tightly integrated with Cisco's Advanced Malware Protection (AMP) solution.
More detail information:
If you have any questions, please don't hesitate to contact us.
