- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Como realizar un cambio de firmware MV cámaras meraki
estoy experiementando agregar la demo de V-app para reconocimiento de placas de vehiculos pero V-app pide tener la version 5.0 por que la version 5.3 experimenta problemas.
como debo realizar mi downgrade?
- Labels:
Cámaras MV
Dashboard
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Rolling Back a Recent Firmware Upgrade
Firmware upgrades can be rolled back to their previous version up to 14 days after an upgrade takes place. Follow the steps below to roll back a firmware upgrade.
- Navigate to Organization > Monitor > Firmware upgrades.
- From the Overview tab, view the Most recent upgrades section and find the applicable upgrade entry.
- Click on the applicable upgrade entry where it lists the number of networks and devices that were upgraded.
- Click the Rollback button.
- Select a reason for the rollback and enter a brief description.
- Select Perform the upgrade now or Schedule the upgrade for, specifying a date and time for the rollback.
- Click Submit to schedule the rollback.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
CAMARAS MV32 - LUZ NOCTURNA
Buenos dias, recientemente hemos adquirido camaras MV32, he instalado una pero monitoreando el movimiento por la noches todo me visualiza negro por completo, mi consulta es si alguien me puede indicar que si estas camaras tienen luz nocturna o bien si puede haber un dispositivo adicional para que pueda verse por las noches, saludos.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Does the MV32 have night vision?
The MV32 does not have night vision. It contains no built-in IR illuminators for very dark scenes. However, it has an IR-cut filter that allows it to be more sensitive to lower-light scenes.
https://documentation.meraki.com/MV/MV_Smart_Camera_FAQ#Does_the_MV32_have_night_vision.3F
