Meraki Piscando Luzes de Rede
thiagomaraujoo
Olá Comunidade, sou novo por aqui e estou com uma dúvida,
Meu Meraki só fica assim, o que poderia está causando isso?
Ligado n
And is the status LED flashing amber or a specific color?
https://meraki.cisco.com/blog/2014/02/the-light-fantastic/
thiagomaraujoo
Amber
In most cases it is because the AP did not obtain an IP or if it did, it is unable to communicate with the Meraki Cloud.
Have you checked if the AP received an IP or any firewall logs?
Have you had to do a factory reset of the AP?
Otherwise, I suggest you open a support case.
