replacing core switches
sherwoods12
We currently have a pair of Cisco WS-C3750X-24T-S switches as our "Core" switch.
We want to replace them with equivalent Meraki switches.
What is a suitable replacement?
4 REPLIES 4
CptnCrnch
I guess it‘s mostly dependent on what kind of features you’re using on your 3750. As core, you‘ll possibly use Layer 3 routing. In this case, MS350 / MS355 would be suitable.
Given that 3750 are rather „old school“, you‘ll mostly not be running into performance issues with nowadays Meraki switches like those mentioned above.
Unless you are performing advanced dynamic routing, a MS250 or greater will be enough.
We actually replaced some 3850s at one site with MS210s, from a performance point of view at that site they were just as good.  We ran the DHCP from the MXs at the site.
Are you using:
  • Policy-based routing
  • Any dynamic routing protocols, and if so which ones
  • Any layer 3 routing at all (or are they only used as layer 2 switches)
rhbirkelund
You might also want to take into account that Meraki requieres internet connectivity.
All code is provided as is. Responsibility for Code execution is solely your own.
