installing a module uplink to a C9300-M
sharon_k
hi,
can someone please tell me when is the best time to install the module uplink in a C9300-M.
before starting the switch ? after the switch connect to the dashboard ?
thanks
It doesn't matter, both will work.
Brash
As per the installation guide, the modules are hot swappable.
"Note: The C9300/X uplink modules are hot-swappable and can be inserted/removed while powered."
Catalyst 9300/X/L-M Series Installation Guide - Cisco Meraki Documentation
Therefore, you can install it any time.
That said, if you have it before booting up and installing the switch, I suggest inserting it beforehand.
sharon_k
great thanks 🙂
GIdenJoe
You can even pre-configure the module ports by using the new C9300-NM-DEFAULT/1 - 8 ports.
The config on these ports will be copied to the actual ports of the module you install.  Great stuff!
