connect meraki SFP module to Dell SFP
MinhTu
I have a question ,
 I want to connect my server with MS410 device by SFP optical port, Server I use DELL's SFP module and MS410 I use Meraki SFP Module. May I ask if they work?
10 REPLIES 10
If both SFPs are of the same type (eg SFP-1GB-SX) and the Dell server recognizes the SFP it will work without any problems.
hi Sir,
example ,
SFP module meraki : MA-SFP-10GB-SR for switch MS410
SFP module Dell Server : SFP+ SR Optic for all SFP+ ports except high temp validation warning cards customer install for DELL SERVER R750xs
it is godd?
If both were the same speed (10GB) it should work.
okay, thank you sir
I'm sure you are aware, but just to note that the SFP+ transceivers will only work in the 2/4 ports at the right hand end of the switch.  The other ports are 1Gb only.
MinhTu
i still understand , so it mean only work on port 33-34 , and port 35-36 is not work, right?
@MinhTu All of those ports are 10Gb, it is just ports 1-32 in your case that are 1Gb.  On the smaller model 1-16 are 1Gb and 17,18 are 10Gb
MinhTu
I still not yet mean understand for you about  :""I'm sure you are aware, but just to note that the SFP+ transceivers will only work in the 2/4 ports at the right hand end of the switch.  The other ports are 1Gb only. ""
In the 16 port model only the last two ports (the ones on their own at the right hand side) at 10Gb, in the 32 port model the last 4 ports (again on their own at the right) are 10Gb
MinhTu
thank you, i understood
