add layer 3 switches to existing network
tech03
Hi
We need to add layer 3 switch (MS-250 Meraki)  to perform intervlan
we have SAS 5506 That connect to vpn (Anyconnect) in vlan 1 ip 192.168.1.1
all connection go from this vlan 1 to the server,workstation,printer,vpn......
we need to divide our network to  intervlan 20,30 and keep vlan 1 manage our server and printer
Vlan 1 for server and printer 192.168.1.0/24(because we can not change server and printer  ips)
intervlan for workstation 192.168.20.0/24
intervlan for wifi 192.168.30.0/24
we alredy create the intervlan interface in the switch and the scope in dhcp server
Name
Subnet
IP interface
VLAN id
DHCP Settings
Mangement vlan
192.168.1.0/24
192.168.1.3
1
off
workstation vlan
192.168.20.0/24
192.168.20.3 20
20
Relay to dhcp server
wifi vlan
192.168.30.0/24
192.168.30.3 30
30
Dhcp server 2016 : 192.168.1.10
we create scope using the switch's routing interface for each VLAN as the gateway
192.168.1.1 for scope 1
192.168.20.3 for scope 20
192.168.30.3.for scope 30
topologie
Problem:
we start move same workstation to vlan 20 for test
Device in vlan 20 Take adress in vlan 20 , DHCP work fine , but  no internet to this device
I can not ping any address from vlan 1 when i'm using  vlan 20 or 30 to , but ping work fine between vlan 20 and 30
Questions:
how to have traffic between my Layer 3 intervlans .Vlan 20 , vlan 30 and vlan 1(native vlan)
until now my pings are succesfull between vlan 20 and 30 but unseccesful when trying to ping vlan 1(native vlan that have all my servers) from vlan 20 and 30
Thank you
Please Advice
2 REPLIES 2
You cant ping devices in vlan 1 because they have as gateway your 5506. But the 5506 does not know where vlan 20 and 30 are.  So you need to create the static routes.
Ip route 192.168.20.0 255.255.255.0 192.168.1.3
Ip route 192.168.30.0 etc..
