Search instead for
Wish: Product Fan information
This topic comes up enough that it would be beneficial for Meraki to include some information in the documentation and/or specs.  There are different types of fans, software is involved, some power supplies have fans, some fans are removable, noise levels, etc.
Re: Wish: Product Fan information
I'd agree, I have a few switches that weren't identified as part of the ones having the fan issue but when I'm physically by those switches I can tell they are spooling up and down.  All switch health info would be useful.  CPU usage, temperature, fan status etc...
@Adam Yikes - get those replaced ASAP. They WILL fail. Be careful not to burn your hands when removing it from the rack.
MRCUR | CMNO #12
