What is the best network topology for audio?
egeerdes
Greetings everyone,
My name is Ethan and I am slightly new to routing and switching in the broadcast industry. I want to make my network fault tolerant but optimized for audio transmission. In my research, I am pretty sure I need to remove all loops, disable RSTP, and I think link aggregation should be implemented but, am not confident on the actual implementation. Would I just link aggregate to the next switch, like a bus topology? I found some switch stacking cables and I am thinking of possibly using those as well. My network is meraki based, I have 4 main switches, and 1 inside a studio. I also have 2 of the mx250's and want to integrate them both for high availability. Any guidance / experience sharing would be awesome. Thank you.
egeerdes
lots to chew on. Thank you.
What switch models do you have, how many locations do they live in and is your traffic mainly in the site or mostly to outside servers etc.?
Hopefully the 3 main switches are stackable.  Simply stack them,  RSTP won't cause any issues if the network is loop free, so I wouldn't worry about touching that.
Use a pair of cables to the fourth switch, and combine them into a channel using LACP.
Ports that go to devices should be configured as access ports.  Ports between switches should be configured as trunk ports.
I would tend to connect each MX250 to a different single switch (one MX to one MS, and the other MX to a different MS), to maintain everything loop free.
