You will get this warning.
If you have other L3 capable switches or stacks in the network you could move it via the Routing & DHCP page. Keeping in mind that might not be feasible or it might impact your production deployment.
How many L3 interfaces are on the stack now? It might be easy enough to just take a snapshot of what you have, delete the stack, then recreate the interfaces on the single switch?
Ryan / Meraki Solutions Engineer If you found this post helpful, please give it
Kudos. If my answer solves your problem please click
Accept as Solution so others can benefit from it.
