Vrf support on a MS250 switch
Hi there
Will there be any support for VRF routning on a Meraki MS250 switch ?
3 REPLIES 3
Re: Vrf support on a MS250 switch
There is no such support, and I think it is unlikely there would ever be support for this.
Meraki is all about simplifying things, and VRFs are more of a service provider feature.  I can't imagine how they could "simply" integrate that into the GUI.
I can see the support for routing in this example.
https://documentation.meraki.com/MS/Layer_3_Switching/Layer_3_Switch_Example
But in my case, the router is from a ISP, and they come with internet, public net, voip, and corporate network, all layer 3 routed.
And i dont want to make acl lists..
You would need ACLs.
Why don't you ask the ISP to break out the networks on separate ports of their router for you.
