The concept of VLANs on Meraki differs slightly from how it works in classical Cisco. In Cisco Classic, we're used to having to create a VLAN first, before we can use it. On Meraki, all VLANs are per default created already. So rather than having to create the VLAN first, and then assign it to a switch port, you can just assign it directly.
On Meraki MS-switches, all plans 1-4094 are created. For a C9K switch in Meraki only VLANs 1-1000 are created.
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
