VRRP across a MS120-48LP not working
mark197
Two (non Cisco) routers not receiving multicast packets from each other. Should be very simple, alas doesn't work
Both switches occassionally see the physical address but with the virtual MAC which should never occur. Virtual IP is 192.168.120.1. All looks ok on a host sat on the LAN.
As seen on Ubuntu host correctly
? (192.168.120.1) at 00:00:5e:00:01:01 [ether] on ens160
? (192.168.120.3) at 00:0b:ab:f6:c1:96 [ether] on ens160
? (192.168.120.2) at 00:0b:ab:f5:d7:a6 [ether] on ens160
Don't understand why this entry would ever occur.
00:00:5e:00:01:01 192.168.120.3
This suggests to me that the routers are not sending IGMP join messages for the VRRP group.  In that case use the multicast flooding option under switch settings.
mark197
Just had a look and these two are enabled
IGMP snooping
Flood unknown multicast traffic
mark197
Problem located between chair and keyboard, typo in VRRP config, bah....
