Uplink from Meraki MS250 (layer2) to Catalyst WS-C6509-E (layer3) via Copper port
ESEInforians
Hi Guys,
Currently I am looking to extend my existing network to connect a access switch (Meraki MS250-48FP) to core switch (catalyst 6509-E) as the core switch.
Would it work (compatibility wise) using copper port as uplink?
2 Replies 2
Yes, the SFP+ and RJ45 ports are functionally identical, just different media and speed options.
Brash
As @cmr said above, it should work without issue.
One thing to be aware of is that your C6509 is most likely running PVSTP+ version of spanning tree while the Meraki switch runs MSTP. Both are interoperable but there are some things to be aware of.
The following doc covers it off pretty well.
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Configuring_Spanning_Tree_on_Meraki_...
