Twinax cables purchase and distance.
MOON
Twinax trunk/uplink cables.
I have two switches that are about 10' apart, does meraki make a cable that long?
If so where can I purchase either Meraki OEM or after market cables that are of the same quality as OEM?
Darrin
Yes, Meraki does offer Twinax trunk/uplink cables that are 10 feet long. The Meraki MA-CBL-TA-3M is a 3-meter (approximately 10 feet) Twinax cable with SFP+ connectors. This cable is compatible with various Meraki switches, including the MS350, MS355, MS390, MS410, and MS425
MA-CBL-TA-3M | Meraki Twinax Cable
You should be able to buy it from the same place that you got your switches.
thaack
FS sells 10ft Twinax DAC cables for $18.
These will work - but please be aware that in the event of an issue support may require you to utilize OEM cables or they could refuse troubleshooting. Not sure if that is a common occurrence - somebody else may be able to chime in on that.
I've personally used third party cables with zero issue, and you avoid paying the Cisco tax. YMMV.
