Switch port with VOIP
one our our customer has connected shoretel IP phones to MS220-8P with voice VLAN.
But have an ongoing issue at one of our SDWAN connected sites. (using Meraki)  The issue is with voice phone quality.  (ShoreTel phone system).
issue is like a user calls to an extension number and call gets dropped randomly and sometimes caller can hear a voice of other person but the other person couldn't hear anything.
And it is happening with only one particular extension(e.g 4414).
can anyone tell me what all i need to check from meraki switch as i am new to Cisco Meraki.
Thanks.
6 REPLIES 6
Re: Switch port with VOIP
Hmm... played around with QoS at all? i suspect since its not a Meraki phone, you may need to setup custom rules.
okay. can you suggest me custom rules like what??
I haven't played with it too much in my environment, as i dont have VoIP - yet.
But i think Meraki makes it easy to classify traffic on a port as voice traffic, setting its QoS priority higher.
In this case, Meraki documentation will be a friend. Check this out: Link to FAQ about VoIP
thanks
was this problem also before? or did it start after an update or something?
one way call is most likely not a qos issue.
I would check the phone as well.  What model is it, 230, 486?  I use ShoreTel as well and configured the QoS in Configure, Switch Settings.  Select your VLAN and leave the Protocol to Any, set the DSCP to... 46 -> class 3 (EF Voice).  Check the settings of the physical port the phone is plugged into and make sure you designated your voice vlan.
