Switch Ports Profiles API broken?
PinkUnicorn
No matter how I try, I cannot make switch port profile API to work, it always returns 404 Not Found. Has it been deprecated?
Ref: https://developer.cisco.com/meraki/api-v1/get-network-switch-ports-profiles/
GET /api/v1/networks/***************/switch/ports/profiles HTTP/1.1
Accept: application/json
Authorization: Bearer ***************
User-Agent: PostmanRuntime/7.49.1
Postman-Token: 06ccd76c-748a-42fd-a795-0569111d09b8
Host: api.meraki.com
Accept-Encoding: gzip, deflate, br
Connection: keep-alive
HTTP/1.1 404 Not Found
Date: Thu, 11 Dec 2025 19:31:52 GMT
Content-Type: application/json
Transfer-Encoding: chunked
Vary: Accept-Encoding
X-Frame-Options: sameorigin
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Robots-Tag: none
Cache-Control: no-cache, no-store, max-age=0, must-revalidate
Pragma: no-cache
Expires: Fri, 01 Jan 1990 00:00:00 GMT
X-Request-Id: 9b7e042b6fc5f9b60ac7ae4c6a53d358
X-Runtime: 0.064642
Strict-Transport-Security: max-age=31536000; includeSubDomains
cf-cache-status: DYNAMIC
Content-Encoding: gzip
Server: cloudflare
CF-RAY: 9ac7679b19b21840-STL
Is there another way to create port profiles via the API?
Thanks.
Ryan_Miles
Meraki Employee All-Star
Port Profiles were merged into the feature called SmartPorts.
https://documentation.meraki.com/Switching/MS_-_Switches/Design_and_Configure/Configuration_Guides/P...
I'm on the road today and cannot currently test, but perhaps the call you need now lives under the smart ports section? I see several smart ports calls in the API Index.
I'm not sure but i think that Meraki does not support switch port profiles via API anymore.
Just Organization Config Template Switch Profile Port.
https://developer.cisco.com/meraki/api-v1/get-organization-config-template-switch-profile-port/
PinkUnicorn
Thank you for the reply, it is confusing that you can still find unsupported/deprecated API details.
The Organization Config Template Switch Profile you are referencing doesn't seem to have a create (POST) API - Maybe with the "createOrganizationConfigTemplate" ? But I cannot a way to link that into a switch profile where I define my standard configuration for VLAN X.
Ryan_Miles
PinkUnicorn
Smart Ports took me to the same API (https://developer.cisco.com/meraki/api-v1/get-network-switch-ports-profiles/) BUT one thing I missed is that it is an Early Access API and access to those must be enabled first.
After enabling the access for the Early Access API, I got the access I needed.
Thank you Ryan.
