Stack setup
SurajRumpal
Stack setup
I have purchased MS390-48UX 2 of these switches along with our MX95. I am wanting to stack the 2 switches together. I have also purchased the Meraki MS390 120G Data stack cable. When I connect these to each switch in a ring topology I then go onto the meraki portal but it does not detect the potential stack. If I create it manually it also does not detect the switches. Am I missing something as on the catalyst series I know the stack is plug and play once connected and automatically sees everything. Do you also need the stack power cables to make this work/ I cannot figure why it won’t work.
Any help would be greatly appreciated.
cheers
suraj
2 Replies 2
Check the documentation.
https://documentation.meraki.com/MS/Stacking/Switch_Stacks#Stacking_MS390s
Maybe try not stacking them together to begin with, and bring their firmware up to the current stable release version, and then once they both show as online and stable - stack them.
