Setup a Multi Site Uplink Redundancy using only Security Gateway
Teme
Hello , i want to setup a Setup a Multi Site Uplink Redundancy using only Security Gateway.
to give you a proper background, we currently have two sites connected on one dashboard.
Site 1
Uplink source -> MX64 -> MS12024P -> Point to Point
Site 2
Point to Point -> MS12048LP
What i want to do is add an uplink source to Site 2 and have it routed through Site 1's MX64
Moving site 1's uplink source is currently not optional and neither is moving site 2's uplink source to site 1.
Thank you
1 Reply 1
Brash
That would be quite the complex setup.
It would seemingly be far easier to place another mx at site 2 so both have primary wan uplinks. You can then set the point to point link as a secondary WAN uplink. Assuming you have the appropriate routing that would achieve the uplink redundancy you're looking for.
But going strictly off what you're asking, unless your point-to-point link is providing some sort of stretched layer 2 overlay, I don't see how you can make it work.
