Setup OSPF between MS and Sophos XG 330
DBesa
Anyone of you have any experience in setting up OSPF between a L3 MS Switch and Sophos XG Firewall? We wanted to go with the MX but unfortunately it doesn't support SSL VPN.
Thanks!
Desmond
TonyC
No direct experience but both support OSPFv2 so should be fairly straight forward!
NathanG
G'day Desmond,
Great question you have there.
Though I can't offer any personal experience integrating an MS to a Sophos device via OSPF, given it's a standards based protocol, it should work out nicely.
Take a look at this article as a starting point:
https://documentation.meraki.com/MS/Layer_3_Switching/MS_OSPF_Overview
It'd be helpful to hear back about your experience.
Nathan
Thanks, Nathan. I will give this a read and will try to setup OSPF between the two devices. Thanks!
