Searching 4 Tips
Hak7
Searching 4 Tips
i am starting to learn about cisco meraki.
i am searching now how to learn and practice with cisco switch.
i want to learn how to set them up.
do you have any knowledge base or labs where i can practice?
thx in advance
8 Replies 8
If you go to the below URL you can click on "Instant Demo", which takes you to a dashboard you can play with.
https://meraki.cisco.com/lp/free-demo
On that page their is also a link to "See upcoming webinars".  These are another great way to learn.  If you are currently working in IT and your company does not have any Meraki kit at the moment then by attending specific webinars you can get a free AP.
Hak7
Hi Philip,
thanks for this information.
i will try it.
i appreciate it!
Nash
What's your general comfort level with network basics? You might try the ECMS1 class for specific instruction combined with lab time.
Hak7
Hi Nash,
i am a beginner an started with the
Cisco Meraki.
i am a CMNA and i want to evolve my knowledge to be a profi with cisco.
i will try it.
i appreciate it!
timeshimanshu
@Hak7  For the Labs you can go to this url gives you the read-only access to some content.They come up with the session timely. keep track of it. https://dcloud2-sng.cisco.com/content/catalogue?search=Meraki%20MS&screenCommand=openSearchScreen&is...
For Meraki MS you can go to https://documentation.meraki.com/MS and find the topic as per your choice.
Hak7
Hi Timeshimanshu,
i will try it.
i appreciate it!
BlakeRichardson
@Hak7  Are you employed? If so you might be eligible for free gear by attending a webinar. Otherwise ask away here and don't forget the knowledge base.
Hak7
Hi Blake,
Yes i am employed and also wait for my free gear but it not arived until now.
I am already checking the kb.
