SNMP V3 Privacy mode AES-128?
Ronny63
HI all , do anyone know if SNMP V3 AES-128 now are fully supported or is DES still the only choice.
Ronny63
I  also asked Meraki support that gave me below answer.
I don't have any confirmation that AES128 is recommended for use in a production environment at this time.
Our current documentation doesn't mention this option as being ready for production.
As the option is currently selectable, you have the option of trying it out if you desire.
If you have any additional questions, please let us know. Thank you.
7 Replies 7
Ronny63
The question applies for all products MX,MS,MR etc.
Theoretically yes, you can enable and configure it in Organization > Settings. Here you can choose between DES and AES (128).
Ronny63
Yes I know it´s possible and also working but still in February it was some issues with AES so Meraki recommended to use DES
So the question are whether the AES problems now are solved and Meraki fully supports it to be used in a production environment.
I think it would be better to ask Meraki support.
I've been using SNMPv3 and AES with a customer for a good year or two without issue.
JanVandenberghe
Just enabled it on a test site and it seems to be working ...
Ronny63
