SFP for MS250
SFP for MS250
I need to connect MS250 switch via fiber to a Ubiquiti edge switch. Ubiquiti using UF-MM-1G (850 nm MM) transceiver. If I use MA-SFP-1GB-SX for MS250 will there by any compatibility issue?
As per the Meraki datasheet I can see different specification:
3 REPLIES 3
Re: SFP for MS250
I cant see you having any issues with this, what type of fibre are you using?
Re: SFP for MS250
As @BlakeRichardson says, that will work fine.  I would personally use OM3 or OM4 fibre.
Re: SFP for MS250
Thanks Guys. Yes planning to use OM3.
Cheers.
