Remote configuration of Wan uplink possible?
StefanoFereri
our MS220 on a remote site was connected to a second Wan uplink for a new internet provider (on port 23). This was done by a technician of this provider. The switch still is reachable via old provider on port 24. Port 23 is configured with different settings (native Vlan 1, Vlans 100-102, DHCP on Vlan 100). When I simply activate port 23 and deactivate port 24 switch goes offline, which is somehow expected. After a while it comes back, presumably because of its self healing features.
How can I make it to switch over to the new Wan uplink? Is there a way to inject a different configuration and reboot the switch via cloud, so that the new configuration comes active?
Thanks and regards
Stefano
6 REPLIES 6
KarstenI
What exactly do you want to change? You say the switch comes back after shutting down the old port. What else do you want to achieve?
sorry, should have been clearer. It comes back - but with old config and reactivated port 24.
Enable both ports.
Then set the management ip setting of the switch to dhcp @Vlan 100. Wait till it gets the ip from vlan 100. Then also set the management vlan to 100 at switch >switch settings
Then shutdown port 24?
StefanoFereri
Hi ww,
I tried that, but it never gets IP from Vlan 100. Message is "This device is using a DHCP IP address from VLAN 10 instead of using configured VLAN 100".
Any idea?
Stefano
Make a packet capture on port 23 and see if the switch send a dhcp  discover and gets  a offer back on vlan 100.
Or try set a static ip or vlan 100
Slobs2
You'll want both ports up, then edit the IP info for the switch (changing the IP, VLAN, etc accordingly), and then you should be able to disable the old port.
