RADIUS ACL attributes
RuslanDevelopex
Can`t find how to assign ACL with Access-Accept RADIUS response and what attributes to use.
There is a Filter-Id attribute that can be used to convey a group policy that should be applied to a wireless user or device. Want to know how to assign ACL via sending id and via sending ACL rules in Access-Accept RADIUS response
5 Replies 5
jdsilva
To do this you'd have to put the ACL in the Group Policy, and then assign the GP. You cannot directly assign an ACL via RADIUS.
To add to @jdsilva answer, here is a brief guide for MR.  I know you ar eusing MS, but it is similar.
https://documentation.meraki.com/MR/Group_Policies_and_Blacklisting/Using_RADIUS_Attributes_to_Apply...
RuslanDevelopex
Thanks for the link! Maybe there is an approach to send ACL rules still as one more option?
No.  You define what ever firewall rules you want in group policy, and then assign that group policy via RADIUS.
RuslanDevelopex
Thanks for your answer!
