- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Problems with printers in different VLANs
Good morning everybody!
We are using Meraki MS210-48 switch, and we have printers in our office on the VLAN 192.168.0.0/24.... connected by ethernet.
We have also wirless public VLAN 10.10.0.0/24, with the firewall rules allow any 10.10.0.0/24 any 192.168.0.250 (IP from the printer)
All computers can reach and install them by lan, but Wireless only the Mac Computers can reach them.
We already put firewall rules (also tried on the WLAN rules), but if we are connected in different VLAN (by wireless), we can not reach them, by ping we can, but not for install them on windows.
Because in mac was working, we tried Bonjour assistant, and from the Wirless Public VLAN I can see them but can not install them (same as with ping).
Any suggestion would be appreciated.
Thanks everyone,
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
We found the problem, it was on a rule on the firewall. Just to inform, the printers should have 2 way rules. Go and comeback.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What is routing between your VLANs?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
thats the point of Vlans Segregation, maybe you knew that but if Vlans cant talk to each other then there ya go.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The router that we are using is the one from the internet provider.
The firewall MX84 is used as a DHCP Server. Giving IPs in the different VLANs.
(We already applied the firewall rules to reach by ping the printers, not working for adding them to windows.)
Is it possible that we can give IP from different VLANs, but there is no connection between the VLANs becasue there is no routing between them? I thought this can be done from the Firewall. We have this in routing and dhcp configuration on SWITCHes: ( "You don't have any interfaces or static routes configured, Create an interface to configure layer 3 settings on your switch").
We have 6 switches, most of them with trunk ports, one of them is connected exclusively for the Wifi APs, who are giving the SSID that we want to use to set up for clientes to use the printers (are users BYOD).
Maybe the firewall can not route between the VLANs?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
In Addressing & VLANS the deployment is set as routed, and as a subnets we have the different VLANs...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
First thing I would do is turn off windows firewall and then see if the printers work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Done, and it's not working 😞
